Knox (guest)
Guest
Posts: n/a
I have a 2002 BMW 325xi and it threw off code P1345 cylinder 2 misfire with fuel cut off I've done a bunch of research and haven't come up with anything to help fix my car. I changed the camshaft position sensor. And went to turn it on after changing and it won't start. It turns over and acts like it wants to start but never actually starts. When I changed the señor I didn't unplug harness that's under intake valve like some info I've read after the fact said. Did that screw up my car more by not unplugging it. What do I do? I need to get this running fast!!
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-28-2014, 01:17 PM
Nick at Pelican Parts's Avatar
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume and quality. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick
