Getting recurring every other day after clearing CEL on my 98 M3. The code comes up at P0412. I have checked and/or replaced all the SAP components with no failures found or other problems. Is it possible the O2 sensor is beginning to go bad and causing this code? thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Hard to say. You would likely have an o2 sensor fault.
When you command the secondary air on, check that the o2 does in fact hold lean. - Nick |
| All times are GMT -8. The time now is 08:06 PM. |
