S50 misfire on cyl 1 - help
I have an S50US that has no compression on #1.
cyls 6-2 = 175 to 185psi. 10k on complete rebuild. new rings/valve guides/seals/bearings/etc It runs GREAT at high load and rpm but poorly on low rpm/low load. If a ring was bad wouldn't it run poorly all the time? I'm stumped. I'll do a cold compression test with some oil in the cylinder next. The leakdown test I did - I can hear air coming from the timing chain area. No air gets out from the intake/exhaust valves. Bad head gasket - leaking into the timing chain area maybe? at 20psi - I do not see any air bubbles in the coolant. It does not use oil - the coolant looks fine also. No signs it's mixing coolant/oil. Odd. Any ideas? Chris Last edited by chris dunlap; 08-29-2015 at 09:40 AM.. |
