BMW318is M44
1997 BMW 318is with M44 engine cranks but won't start.
Replaced fuel pump 4years ago, but now doesn't seem to be working.
Don't remember how to test. Help!
Old 09-29-2015, 11:54 PM
Have you checked fuel pressure? Also, do you have a test light?
Old 09-29-2015, 11:55 PM
Or a obd2 scan tool
Old 09-29-2015, 11:57 PM
Only have multi-meter.
Checked fuse (18), seems okay.
Should I have 12V at fuse plug or pump when Ignition on?
Old 09-30-2015, 12:06 AM
Had that similar problem, turned out to be a corroded DME relay and crank sensor
Old 09-30-2015, 12:07 AM
Yes I think so, if your by/on a computer go to realoem.com and look it up. It should tell you if not.
Old 09-30-2015, 12:09 AM
Not by a computer or I'd look it up for you. I'm looking in my chilton Manuel. Don't have my Bentley work book with me
Old 09-30-2015, 12:11 AM
