I have a issue with my 1997 e36 m3, It only happens when you get on the throttle and rev up past 5500rpm. What is happening is when i shift from 1st to 2nd and im at top of 2nd gear shifting to 3rd it seems to fall flat on its face. I lose all power, but i get no CEL or stalling. If i give it gas it gives the sound of the intake chugging air, but again i dont stall. I have to blip the throttle and down shift back to 2nd gear and pull over on the side of the road. Once i stop on the side of the road i can start driving again. It does not do this unless i rev it up high into the rpms, if i keep the shifting at about 4500 to 5000rpm it drives and pulls hard. But anything above it bogs down and loses all power. Any thoughts to the issue?
__________________ This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Oxygen Sensor - O2 Sensor - Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article |
Could be an issue with the fuel pump. I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick |
| All times are GMT -8. The time now is 02:20 AM. |
