Stalls during right turns
I have a 1987 325is. Once up to temp it will stall at low speed when making a right turn. It happens without touching the brakes. It will happen under power and in gear, in neutral with clutch depressed or released. I've seen this mentioned on other posts with a variety of thoughts. My local mechanic has no idea. I have a few thoughts but want to see what your experience is with this. Thanks!
Old 04-29-2016, 07:40 PM
Administrator
Luccia at Pelican Parts's Avatar
Hello, are there any fault codes present in the system? Does it sputter and then stall or does it just turn off?
Old 05-09-2016, 02:40 PM
