-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   engine stalls/hesitates under load close to operating temperature (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/912608-engine-stalls-hesitates-under-load-close-operating-temperature.html)
markw1954 05-01-2016 09:57 PM
I have a 1986 325e. The problem is intermittent with the engine hesitating and sometimes stalling when accelerating from from idle but always happens at about reaching operating temperature. Once operating temperature has been reached there is no issue. only happens on first start of the day. Any ideas??
Luccia at Pelican Parts 05-09-2016 02:18 PM
Is your check engine light on or any stored codes?
markw1954 05-09-2016 05:49 PM
No, Check engine light not on, no stored codes. i have just replaced the coolant temp sensor as it appears to be temperature related. hard to tell if this has worked yet as the issue is intermittent - only happens 2 or 3 times every 2 weeks - always on first run of the day.
