-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/916566-question-bmw-3-series-e36-o2_sensor.html)
Claude (guest) 06-02-2016 03:37 AM
Hi Nick,
I have a 92 325 nv with 100k miles on it. When the revs are below 2000 rpm and I get back on throttle the car bogs and missfires. Sometimes ill hear crackling from the cat conv. This winter I have replaced plugs and a bad coilpack as well as the vc gasket. I've narrowed it down to : O2 sensor, coil pack, bad cat, dirty maf or vacuum leak in ccv. What are your thoughts? Thanks
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Oxygen Sensor - O2 Sensor - Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 06-02-2016 03:37 AM
Only a few things can cause a misifre, you'll need to see what is missing. I would check spark, fuel and compression on all cylinders.
- Nick
