-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   CA SMOG Check failed (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/919097-ca-smog-check-failed.html)
boldm28 06-21-2016 10:13 PM
CA SMOG Check failed -- suggestion welcome
So I get the dreaded SMOG test thing in the mail and since I had a very hard time last time
here is what i did
1) added techron Fuel injector cleaner to full tank of gas
ran it to almost empty
2) after that I did go for an oil change
drove for about 15 miles on free way on 4th gear and got into the smog test station(Star certified)
First attempt -- Fail
15 miles
HC MAX 85 MEAS 88
CO MAX 0.34 MEAS 0.42
NO MAX 486 MEAS 871
25 miles
HC MAX 35 MEAS 35
CO MAX 0.30 MEAS 0.30
NO MAX 502 MEAS 312
Basically I failed at 15 miles and passed at 25 miles
Second Attempt Fail
3 gallons with a quart of denatured alcohol
replaced airfilter
Drove on free way for abut 15 miles and straight to a smog station
15 miles
HC MAX 85 MEAS 145
CO MAX 0.34 MEAS 0.56
NO MAX 486 MEAS 1144
25 miles
HC MAX 35 MEAS 35
CO MAX 0.30 MEAS 0.10
NO MAX 502 MEAS 75
It is a 95 318is everything stock and has 250 K miles on it -- transmission manual
how can there be such a huge difference in NO 75 vs 1144
Suggestions , ideas
allenwilson33 07-07-2016 11:00 PM
Your nitrous oxide emissions increased at 25 MPH, not 25 miles, to clarify. I don't know who told you to drive around a lot before you went to get SMOG tested, but you want that engine as cold as possible when you go, so for what it's worth, I'd try to find another smog station that's much closer than 15 miles from your home.
Nevertheless, your data is pretty indicative of an aged Cat. You could always replace the Oxygen sensors if you inspect them and find them to be crusted white with carbon, but it's possible that you could actually read higher nitrous emissions once you get a more accurate (new/clean) sensor.
You can clean the throttle body and idle air control valve for free, but you're not in for a cheap fix.
