-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on BMW 3-Series E36 O2_Sensor (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/928776-question-bmw-3-series-e36-o2_sensor.html)
PAMBOS (guest) 09-13-2016 04:51 AM
Hi.I just bought a 320i 24v and the car was missfiring.So we change the plugs the coils 6the tensioners the ping sensors but the car still dosnt drive well.Is like someone pushing it buck.When you are with the first gear and try to go the RPMS are not going more than 5000.please help
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Oxygen Sensor - O2 Sensor - Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Nick at Pelican Parts 09-13-2016 04:51 AM
Is the check engine light on or flashing when the problem is present? Sounds like an engine misfire. I would check spark, fuel and compression on all cylinders.
- Nick
