Guest
Posts: n/a
Weird rattle under valve cover?
I find this sight very helpful and have 1995 325i it's got 256000 on it and has a Radle under the valve cover.was wondering if you might be able to give me some insite.
__________________ This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Intake Manifold Removal (1992 - 1999) | Pelican Parts DIY Maintenance Article |
Check if the timing chain tensioner is working correctly. If so, the noise could be valve lifters.
- Nick |
Administrator
Anyway you might be able to post a vide of the rattle? Sometimes, the tensioner grows weak and begins to fail, causing the engine to give off an annoying rattle on deceleration. This rattle grows louder as time passes and may become more noticeable at slow speeds.
Timing components here if needed: PelicanParts.com - 1995 BMW 325i Base Sedan - Engine. Some timing info here: http://www.pelicanparts.com/bmw/techarticles/101-Projects-16-Tensioner-Upgrade/101-Projects-16-Tensioner-Upgrade.htm Last edited by Luccia at Pelican Parts; 10-20-2016 at 10:28 AM.. |
