-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Questions on E36 M3 Engine Rebuild (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/936581-questions-e36-m3-engine-rebuild.html)
wswilburn 11-21-2016 06:24 PM
I'm planning to rebuild the S52 engine in my 1998 M3 to stock specs after 240k miles. Reason is head gasket leak plus several oil leaks, thought I should just go through the whole engine. It is now on an engine stand in my garage awaiting disassembly.
Questions for anyone who has the time and inclination:
1. Do you know of a competent machine shop in Santa Fe or Albuquerque?
2. What should I let the shop do, vs. what I do? In particular I'm thinking of who should install piston rings, rod and crank bearings, rod bolts. Top end is more obvious.
3. What should I also replace, other than gaskets and other obvious wear items. Start is a goos example as it appears to be a PIA with the engine in.
4. Any other suggestions?
Thanks!
Scott
Dmitry at Pelican Parts 11-22-2016 02:06 PM
Hi Scott - I've attached a link to our tech articles on the E36, each one lays out a step-by-step guide, with images and detailed text. If you're able and comfortable working on your M3, you can likely do a majority of the work yourself and save a lot of $$. If you're still going to be looking for a local mechanic, trying posting in our Classifieds section, you'll likely get more eyes there - be sure to include the city/state in the thread title. Hope this helps and best of luck! :)
BMW 3-Series E36 (1992-1999) Technical Articles
-Dmitry
