Douth
E36 headlight switch turns on emergency flashers instead of headlights
I have a 1991 320i e36, I have fitted a new headlight switch and it now turns on the emergency flashers instead of the headlights. It works on the first notch for the park lights so I am at a total loss Can you please help?
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Headlamp Switch Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 03-13-2017, 04:41 AM
Possible you installed the wrong switch or the switch was not faulty. It could be an issue with a short. I would get a repair manual and check the circuit. Confirm if the switch is sending the right voltage when the lights are turned on.
- Nick
Douth
Thumbs up
Hi PP, Found the fault, moisture in the fuse/relay all good now, thank's for the reply.
Regards,
Paul
Old 03-13-2017, 11:04 PM
