-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Question on E30 Idle speed troubleshooting (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/950177-question-e30-idle-speed-troubleshooting.html)
gayan (guest) 03-20-2017 11:29 AM
hi pelican I have bmw e36 318i 4 cylinder m42 car,the problem is after start engine within within 5 sec engine automatically stop.if i push throttle after start abt 1000rpm abt 2min then only idle stable 900rpm.can i give me any answer for this...thanks
This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Idle Speed Troubleshooting (1983-1991) | Pelican Parts DIY Maintenance Article
Casey at Pelican Parts 03-20-2017 11:29 AM
Sounds like you have a vacuum leak. Check the intake system for leaks, and don't forget to check the rubber boot for the mass airflow sensor.
- Casey
nfl72 03-20-2017 11:35 AM
The running joke in the car business was
if you had a used BMW on your lot and the "Check Engine Light" was not on; it was because it was broken
Luccia at Pelican Parts 03-21-2017 09:37 AM
You can smoke test the system or have a shop do it for you if you don't have a unit. Can use this site to help you find an indy shop that can perform the test: https://www.bimmershops.com/
