Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Langers's Avatar
Head Bolts
I've been doing a bit of reading, and it seems that the head bolts on these cars are rather fragile. The link I have posted, however, is not clear on how to tell whether the bolts have been replaced or not. One person says that if the bolts look as though they will take a hex head they are fine, whilst another says that if it looks like it will take a hex head, replace them ASAP.
Anyone know for sure?
Pictures? (Wayne? Should be somewhere in your book)
Thanks in advance
Old 01-21-2003, 12:42 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
In the shop at Pelican
Jared at Pelican Parts's Avatar
BMW reccommends that you upgrade the head bolts to the Torx style head if they have not already been changed. I performed this on my car about three months ago. With the head still on the mtoor, just replace them one at a time and you'll be ok.
Old 01-21-2003, 07:43 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Pelican can supply you with these bolts. Keep in mind that the ealier hex head bolts become brittle over time. One day i was driving home when all of a sudden I head a loud "PLINK" from under the hood, then there was this wierd vavle noise, I immediatley pulled off the valve cover to find that one of the hex heads had broken off the bolt and was flying around indside the valve cover. Thank god it didnt get under the camshaft, or It would have cracked it. I changed all the head bolts the next day.
Old 01-21-2003, 01:04 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Langers's Avatar
Aah thankyou very much for your help, you must have ESP, I was going to ask whether they could be replaced one at a time to save the head gasket but you got there before I even asked. Great service!
Old 01-21-2003, 04:26 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Just keep in mind that BMW has a odd way of torquing them. You need to first torque the bolt to 22 ft/lbs, then turn the bolt exactly 180 degrees. I would reccommend also staggering the sequence in wwhich you do the bolts. for instance start with the frontmost intake side, then the rearmost exhaust side, then the rearmost intake side, etc.. This will help relieve pressure on the head gasket.
Old 01-21-2003, 04:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
I'm starting to see more and more of the "torque to yield" kind of installations.
BMTroubleU uses the...
Give them all a 22 Foot pounds of torque, then...
Go back over them with a "Stage 2" torque of 90 degrees, then...
Go back over them with a "Stage 3" torque of another 90 degrees.
My helicopter has several items that require a 30, 60, 90 inch pounds setting, but not a combination of inch pounds AND degrees.
Dan
'86 325
'97 328is
'03 V-Max
Old 01-22-2003, 02:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Im not even really sure why they have these types of settings. seems to me that the composition of the bolt would not vary enough to actually require this. And besides if the bolts were of a metal that flexed that much, wouldn't you not want to use them in the first place?
Old 01-22-2003, 03:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
I'm not so sure it's a matter of bolt metallurgy (it WAS in the beginning, prompting the need for a batter grade bolt, hence the TORX type head, to distinguish from the old stock), but, rather the expansion coefficient of the aluminum head when heated. The amount of repeditive expanding and contracting (when cool), tended to cause fatigue in the old bolts.
If I was a betting man, I'd bet that the engineers said .. "lets get a Grade 8 bolt, set a tare, or running torque as a baseline, and find a good happy medium of "goodentight" and see how the head holds up after many cycles of this expansion thing.
The old adage of "let's use some German torque, which is defined as tighted down till the bolt smokes, then back it off one flat," may have some basis of truth, after all.
"Torque wrench?... Don need no steenkin' torque wrench....."
Dan
'86 325
'97 328is
'03 V-Max
Old 01-22-2003, 03:44 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Piano,
Thanks for the info. I was not aware of that. Im glad to hear that they at least dont use these bolts on helicopters. Can you imagine what cars would be like if they built them to aircraft standards?
Old 01-22-2003, 04:08 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Yep. Helos use VERY expensive, critical dimension, one time use hardware. The rotating bolts (on the rotor head),have serial numbers and lot numbers and get changed every 600 flight hours, no matter how good they look.
Dan
'86 325
'97 328is
'03 V-Max
Old 01-22-2003, 04:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
