Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
rene1651 (guest)
Guest
Posts: n/a
Hello, i have a BMW e46 318i 2000 when i has 1/4 on my fuel gauge the car just stop, i remove the fuel pump and in the side where is only the float reserve side had fuel but the side of the pump with float is empty. my question is why the float side hose does not suck fuel? i check it out and everything looks good.
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Fuel Pump Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 06-29-2017, 09:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
The pressure from fuel pumps goes to opposite side of tank and runs past a siphon valve that keeps an even level in each side. The pump or siphon is likely faulty. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
