Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Paolo (guest)
Guest
Posts: n/a
Can you tell me how I find TDC without removing the radiator and looking at camshaft sprocket? Do I just turn until lobes are down and away from rocker or is there a more accurate method to find it? Thanks
This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Valve Adjustment (1983-1991) | Pelican Parts DIY Maintenance Article
Old 06-30-2017, 09:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Rotate the engine to TDC using the mark on the crank pulley, then work with cylinder 1. Once done with that cylinder, rotate engine until cylinder 2 valves are on the round part of the camshaft, intake and exhaust. Adjust valves and move onto the next cylinder following the same steps.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
