Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
richard (guest)
Guest
Posts: n/a
hi. i was getting code p0340. cam position sensor wiring fault. i have checked the wiring and all is good.
i bought a new intake side cam sensor from our bmw store the box said vdo..my old sensor stepped down from big to small..and the new one is just a wide as the hole. but im still getting fault code p0340..even after resetting.
sometimes the car takes longer to start..and sometimes it fires right up even when cold..but when it takes long to start the fault code comes back
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Camshaft Position Sensor Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 07-14-2017, 05:00 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Best bet is to test the signal at the DME. Confirm it is getting there.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
