Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Dan (guest)
Guest
Posts: n/a
Put the car back together after replacing all the manifold gaskets, coolant and vac hoses, fuel pressure regulator and the air temp and engine coolant temp sensors. Started right up, but seems to be running really rich. Is it true the ECU needs to 'relearn'? Thanks! 95 E36 Convertible Automatic OBDI
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Intake Manifold Removal (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 08-30-2017, 05:30 AM
No relearn needed. You can try to reset all adaptations using an advanced BMW scan too. however, that should be necessary.
- Nick
