Go Back   Pelican Parts Forums > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Ryan (guest)
Guest
Posts: n/a
Okay I have a 1994 BMW 325i 6 cyl its been parked for about a year I was told. The guy I bought it from changed the fuel pumps and relays. I did research and figured it would be the crank shaft position censor so I bought a genuine one for $150, replaced it, and still not getting fuel or spark. The guy I bought it from says he diagnosed it by the book and suggested it was the computer dme/ecu I guess. I don't know what to do next. Could the computer be bad? I'm in need of help asap. Battery does not keep charge , every time I try to test it I have to leave it on cables, not sure if that would have anything to do with it. If I change the ecu would it have to be the exact same serial/model number ? Or could it be a used one of that year? And if not the same model number would I have to get it flashes?
This post was auto-generated based upon a question asked on our tech article page here: BMW E30/E36 Crankshaft Position Sensor Replacement | 3-Series (1983-1999) | Pelican Parts DIY Maitenance Article
Old 08-30-2017, 05:38 AM
it could be the DME. if the DME has all power and grounds, as well as cam and crank signal, I would suspect it. Confirm there are no fault codes that would block starting. You will need the same part # DME.
- Nick
