Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Hazem (guest)
Guest
Posts: n/a
have an e36 with m52b25 engine and everything running great except the increase of fuel consumption. I got the car scanned and it threw the below codes
1- 068 tank ventilation valve. Electrical failure.
2- 065 camshaft sensor
3- vanos mechanically jammed. after erasing the codes and drove the car for a while and scanned it again this issue dissapeared but the first two errors are fixed.
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series VANOS Oil Line and Solenoid Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 08-30-2017, 06:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
I would assume the VANOS actuator is faulty. It would set those codes (minus the evap leak) and give you the symptoms .
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
