Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Jordi Nin (guest)
Guest
Posts: n/a
Hi, Can somone pleae tell me what I have done wrong and how to fix? do I need to remove he whole sunroof assembly?
Recently I replaced headlining in evo 98 e36 M3. I didn't remove it, purchased the car with it out. Putting it back in went smoothly but the sunroof shuttle does not tilt when you tilt the sunroof. Backwards and forwards is smooth, no issues. I am wondering if I can fix by just removing the sunroof or do I need to remove the whole headlining and cassette?
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Sunroof Removal and Repair (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 08-30-2017, 06:43 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
if the guides or track needs repair, sometimes you can remove panel and repair in situ. Most times it is best to remove from vehicle, then inspect and replace what is broken. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
