Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Kennycaine (guest)
Guest
Posts: n/a
I have a 1993 BMW 325is. I am experiencing a 90 milliamp draw on the high beam circuit. Fuses 29-30 draw 40 and 50 milliamps in a key-off position. Remove one fuse and the remaining one shows 90 milliamps. My fog lights are not working now so I was wondering if, because BMW grounds the foglights through the positive high beam circuit, that the foglight switch may be bad and thus causes the drain. My other thought was the stalk switch which activates the high beam having a short. Definitely there is a short somewhere.
This post was auto-generated based upon a question asked on our tech article page here: BMW E30/E36 Electical Problem Troubleshooting | 3-Series (1983-1999) | Pelican Parts DIY Maitenance Article
Old 09-07-2017, 09:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
You will have to unplug each component on the fuse until the draw goes away. I don't have wiring for your vehicle, so I can't be more specific.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
