Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
rnjp (guest)
Guest
Posts: n/a
I checked the brake booster vacuum line as suggested below. It was fine. Also did a smoke leak test, nothing obvious. What parts to start swapping first? Crankcase Vent Valve? TPS? Coolant Temperature Sensor?
This post was auto-generated based upon a question asked on our tech article page here: BMW E30 3-Series Idle Speed Troubleshooting (1983-1991) | Pelican Parts DIY Maintenance Article
Old 09-07-2017, 10:11 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Try clamping off the idle motor hose, does the idle drop? if so, the motor may be stuck open.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
