Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
ljones (guest)
Posts: n/a
My 95 325i has a production date of 4/95. When I took out the tensioner, it has a flat style piston, no fork, no groove. Does that I mean this step does not apply:
"Place a new sealing ring on the tensioner, and insert the tensioner into its hole in the cylinder head. At this point, the two small fingers on the tensioner should line up with a mating ridge on the chain guide inside the cylinder head."
Is it that easy for my car? remove, replace the spring and washer. Tighten back into place, no alignment necessary!? Of course torque to the proper value. Do you know the torque setting? Thanks!
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Lower Chain Tensioner Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 09-13-2017, 06:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
yes, should be as simple as replace the tensioner and e the sealing washer. I donít have torque information.
I would suggest you grab a repair manual, you should own one. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
