supertack's Avatar
BMW Roundel "whisling" Noise Drivin Me Nuts
From the 'stupid question' department:
I've got what can only be described as a cross between a whistle & bird chirping noise when the climate control fan is at it's lowest (2) levels. I know, pretty dumb huh? The problem is I can't seem to pin point where it's coming from, & when the fan is on the higher levels (beyond the first two bars), it goes away. It would seem like this should be a pretty easy thing to correct, but I'm not sure where to start. Any suggestions?
Thanks.
97 328is
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 02-17-2003, 05:19 AM
