Go Back   Pelican Parts Technical BBS > 2- BMW Forums > BMW Technical Forums > 101 Projects Discussion Forum: BMW 3-Series
Dangeruss (guest)
Guest
Posts: n/a
I refreshed my shift bushings, coupler, etc in my 95 M3 and it firmed up the shifter nicely, except now the shifter vibrates in 2nd and 4th until about 3500-4000 rpm and it will pop out of 4th I'm on light throttle, it seems to stay in 4th with either full throttle and when I'm coasting. Thoughts?
This post was auto-generated based upon a question asked on our tech article page here: BMW E36 3-Series Shift Bushings Replacement (1992 - 1999) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 03:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
This is only after the bushings? If so, the shifter length or alignment may have changed during the repair. Detach the rod, then manually shift into the gears giving you trouble. Then lift the shift rod up, does it fit easily or look like it needs adjustment?
- Nick
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
