I have read on all the forums that you should replace the water pump when you replace the timing belt. A local garage in Chattanooga (bavarian-auto)said it isn't necessary on a BMW.
What is your opinion? If it's not necessary I can save the money. I have no previous records on service. 88 325IC thanks for any input.
Mike 88 BMW 325IC 02 V Star Classic 00 Honda Accord |
Mike:
a lot of times they are just trying to make extra $$. In the event that your water pump does go, its about the same amount of labor. The water pump usually fails from corrosion, so changing that coolant every two years will ensure long water pump life. How many miles does your car have? If its up around a 100k and you have to change the timing belt anyway. (good idea if you dont know the service history) might as well do the pump for piece of mind. |
Senior Advisor
I agree with Jeff, if already taking it out and you plan on keeping the car, go ahead. Inspect it when its out.
...96 Chevy heavily Modded such items include... lil' pine tree air freshner.... duct tape rht front arm rest (i'ts falling) zip tie holding in rear tail light.... hi concentrate windsheild washer fluid... sticker of Speedy Gonzales..rear bumper... |
thanks, all belts & water pump are being replaced today
FWIW, I agree that you made the right call. I have done the timeing belt job myself twice and I replaced the pump also. It is a good amount of work to get to the belt. To replace the pump, you have to remove all of the same components. To save the hassle of going through it again, I think it is worth the extra 50 bucks for the pump. Alos, hopefully they replaced the belt tensioner when the belt was replaced. Same argument applies - not that much money for the part and you would hate to have it fail later.
Gregg |
