supertack's Avatar
BMW Roundel Shift Knob Replacement
I'm looking to replace my manual shift knob & need some help. I know (from an earlier post on this forum) that it just pulls off, but the detaching/reattaching of the boot is confusing. What is the best procedure for doing this without having to replace the existing boot? Thanks.
Old 02-08-2003, 01:13 PM
Senior Advisor
Javier at Pelican Parts's Avatar
What kind of car is it? Unless it's an M3 with lighted knob, it just pops up, a little firm but no screws attatched. If an M3 with lighted it also pops up but watch for the wire harness as not to pull them all the way out.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 02-10-2003, 08:22 AM
supertack's Avatar
Sorry, not an M3. '97 328is, & I was really tring to figure out how to detatch the boot from the bottom of the knob.
Thank.
Old 02-10-2003, 12:31 PM
supertack's Avatar
The boot appears to be attached to the bottom end of the knob. If it wasn't, how would it stay up close to the knob end?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 02-10-2003, 05:04 PM
Senior Advisor
The upper part of the boot has retainer inside the leather that holds itup, had when you slap the knob down it kind of hugs the edge. Know the exception to this is if the original owner modified it and changed it to one off the M3 in that case the boot and knob are one piece. In that case remove boot from center counsel first peel back over the knob and proceed to pop off the knob firmly straight up.
Old 02-11-2003, 11:15 AM
supertack's Avatar
No way it's an M3 knob. Thanks, I'll give that a try.
97 328is
Old 02-11-2003, 12:40 PM
