Convertible Window Problem?
On my 98 323iC, when I put up the drivers window, it often raises, stops, then goes back down about two inches. The only way I found to get around this is to manually press the button every two seconds. Anyone have this problem or a solution? Thanks!
I have the same problem with wy 98 323ic, let me know if you find any solutions!!!:rolleyes:
I have a similar problem with my 96 328iC. It raises the window about two inches and stops. I press the button again and it finishes raising the window automatically.
| All times are GMT -8. The time now is 04:51 PM. |
