View Single Post
Rush2252 Rush2252 is offline
It sounds like you have a blown fuse, if the obd II port isn’t working. Did you check all of the fuses under the hood? It’s possible that the key lost programming but not likely. Focus on getting the code reader to work, whenever you insert the key and press the start button one time do the gauges come on to include the check engine light?
Old 11-13-2019, 11:19 PM
