View Single Post
BURN-BROS BURN-BROS is offline
BURN-BROS's Avatar
Here are some loose specs off of the one I picked up recently.
mains 60 mm dia.
rod journal 53mm dia and approx 24.25 mm wide
I always figured that the 66mm 9 bolts had the same journals as a 66mm 6 bolt. It would have made more sense since they had loads of race inventory from the 2.0/2.2.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
1071 Avenida Acaso suite D Camarillo, Ca.805-240-6931
https://www.instagram.com/burnhamperformance/
Old 10-24-2005, 05:27 PM
