View Single Post
Dave at Pelican Parts Dave at Pelican Parts is offline
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
In general, the factory did not put extra pieces on the car. Everything that's there is there for a reason.
The plates just under the cylinders and heads, which bolt to the case on one end and the head on the outer end, are absolutely critical for proper engine cooling. They help to keep the cooling air moving to the proper areas.
I'm not certain that the ones below that (that screw into the case, the thermostat bracket, and the heat exchangers) are as vital, but they are probably a good thing to leave on. They aren't there for no reason at all, so unless there is an overwhelming reason to get rid of them I would suggest keeping them.
--DD
Old 06-26-1999, 07:47 AM
