View Single Post
JFairman JFairman is offline
I agree with you there... driving slowly and no where near boost through neighborhoods and using 100% synthetic oil is good enough to cool down the turbo housing and the cool down idleing isn't really needed then.
I'll try the 1500-2000rpm idle ignition cut and see if it stops the usual start up puff of oil smoke.
I have Royal Purple regular synthetic 20w-50 that goes for around $7/quart along with some comp cams engine break in additive sourced from murray's speed shop in west palm for increased ZDDP in mine right now and I've stocked up on Mobil 1 V-twin 20w-50 for my next oil change.
Walmart is the cheapest place to get the Mobil 1 V- twin 20-50 oil in it's little motorcycle section (around $8.40/quart)...
I depleted the west palm beach, and jupiter walmarts supply a month ago so they should have more by now...
thanks,
Jim
Old 12-25-2007, 12:25 PM
