View Single Post
stup stup is offline
Used obx headers for nearly 2 years now with absoloute no problems whatsoever,used on the track/street and also several dyno sessions where they have been subjected to extremes!
Please do spend time though cleaning out internally and also i made a jig up to tweek them here and there a little so they fitted on with ease!
If your hands on these are great value for money in my opinion...If you expect to receive them and then slot them straight on then they probably are not for you!
Here is what i used to clean internally then i washed inside..I used a strands from a wire sling then bent each end at 90 degrees fitted in a drill and and run internally near at all the welds..If you go this way be carefull when wire is spinning round and wear thick gloves like shown as the wire will take your skin clean off when revolving
SP Autobahn www.spautobahn.co.uk
Porsche inspector for Peter Morgan UK
http://www.porscheinspections.com/
"92" 964 turbo,Modified and recently rebuilt using all ARP hardware..
Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj.
Old 02-05-2010, 10:45 AM
