View Single Post
A930Rocket A930Rocket is offline
OFF THE BOOST PIPE NOW...
A930Rocket's Avatar
Sounds like CD box is getting power.
Did you check for spark at the plugs or the coil wire? Check both to try and narrow it down.
If no spark at either, then check your coil and the coax wire to the CD box. Maybe tap the 1"x3"x3" silver box mentioned above. Can it be jumped guys? All the wiring under the drivers seat can be removed and it will run. Mine's been removed for years.
Old 03-01-2010, 06:13 AM
