porsche 930 4 speed shifter
I just bought a Porsche 930 shifter 4 speed to replace my 915 5 speed for a conversion. I noticed the metal bracket on top is not there like the one on the 915. Can anyone explain why the 4 speed doesn't have that piece. Guess that's the reverse lockout? I think it must be inside the case but wanted to ask anyway.
Old 06-02-2018, 09:38 AM
Roby466's Avatar
the reverse on the 930 gearbox is left and up, sort of like the old VW boxes but without having to depress the shift lever. Actually it's like the Audi 6 speed or BMW boxes. The 915 has it right and down just below 5th gear. The lock is important so you don't go into reverse coming out of 5th...
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 06-02-2018, 04:22 PM
Thanks for the response!
Old 06-03-2018, 12:13 PM
jbrown's Avatar
I have a 83 911 sc chasis and I put a 930 gearbox in my car and i used mu original 915 shifter and it worked fine. Just curious why you had to change... John
83 sc cab turbo widebody. 3.5 liter supertec motor, B&B headers, EFI electromotive TecGT, TurboKraft GT35R billet turbo, 964 cams, WM inj, Bell full bay intercooler, Short bell housing turbo 4 speed tranny, roll bar, hargett shifter,
Old 06-08-2018, 07:17 AM
changed from 5 speed to 4 speed
Old 06-10-2018, 07:05 PM
Brando
quattrorunner's Avatar
I also used the 915 shiftier but bought the wevo just to make sure I got things right for the 4 speed
Turbo powa!
1977 911s. it's cool
Old 06-11-2018, 10:15 AM
Do i need to modify the 915 shifter in any way to use on the 930?
Old 06-27-2018, 12:16 PM
jbrown's Avatar
I didn't have too... shifted fine when I was done.
John
Old 06-27-2018, 12:51 PM
What about the reverse lock out spring on the shifter? Does that just stay on? I understand the reverse position is left and up due to that being internal in the transmission box.
Old 06-29-2018, 05:11 AM
915 to 930 shifter help
Do I need to modify anything other than the knob on the 915 shifter? I also have an actual 4 speed 930 shifter, but If I don't need to swap them out I won't...
Old 07-01-2018, 05:35 AM
