Groucho Marxist
Tobra's Avatar
Harbor Freight has rubber pads that fit their jack stands perfectly. Protects the undercoating well, and is literally made for the job. Fit my old jack stands okay, and were fairly cheap.
Glad to hear you were not crushed by your car.
"We've got to clear some of the room out of the prisons so we can put the bad guys in there, like the pedophiles and the politicians."
Kinky Friedman
Old 07-06-2018, 10:30 AM
I recommend sturdy light concrete blocks instead of jack stands.
- or alternatively large wood blocks
Played my own share with jack stands, but for 15 years have used big wood blocks and light concrete blocks.
It is okay to play, but not with lifting a car.
'76 930
Old 07-06-2018, 10:31 AM
Work in Progress
Rich76_911s's Avatar
Maybe you have special Finland concrete blocks, but our standard US fair concrete blocks should not be used to support a vehicle. They aren't built for that kind of load.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 07-06-2018, 11:53 AM
Alan L's Avatar
I have seen several crushed concrete blocks under vehicles. Definitely a No-No. They would be the last things I used. Even then, I wouldn't use them. I even had one fail under my boat trailer - weighs way less then my cars.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-06-2018, 12:08 PM
Have used blocks similar to these:
https://www.talotuote.fi/HARKKO-RUH-290
4MPa, so it will take about 68 tons per block. Mind you, if you'd place a sharp object between the block and floor, the block may crack, though it will not disintegrate.
On a nice and tidy floor I'd prefer to use wooden blocks, as the light concrete blocks bring a bit of dust.
'76 930
Old 07-06-2018, 12:23 PM
Originally Posted by flightlead404 View Post
Only after the fall! No, I use a jack stand under each of the front control arms and one under each rear torque tube cover.
Now, as a safety precaution, a hoist and chain around the rear bumper mounts.
Chains on both rear mounts ?
Can the car still slip off the front jacks ?
Yeah, definitely not concrete blocks as the others have said.
Wood is fine, that's what I use to support and brace the tires whenever the car is up.
I can't afford that.
Old 07-06-2018, 12:27 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
About six years ago, I made a set of my own wood block supports out of 2"X12" boards that I screwed () together (sizes for chassis support points and also to go under the wheels when I want, for maximum height) - all are stackable and I even put sturdy handles on the sides of them so I can easily move them around (big and heavy, obviously) - I also put rubber matting on some of them. I got the idea when I saw old-school pics of race teams using wooden blocks for supports. I have never felt safer under a vehicle.
Old 07-06-2018, 12:30 PM
Large chunks of wood is always good. Mind you, as years have passed, I now need both hands to hold morning wood down.
Yes it is about being safe under car, also like to add something underneath in the middle, just as a precaution.
'76 930
Old 07-06-2018, 12:40 PM
Since people like pics (not of Highway's two-handed morning wood, however!!!), here is what I was babbling about.
BTW, even though there is no problem with it, I would not work under the car when it is supported with the 2X4 section on the lift point - I always put supports under the wheels if I'm going to be under the car.
One pic shows the wheel support size under the rear control arm - works great there when max height isn't necessary.
Old 07-06-2018, 01:01 PM
Turbo Powered Snow Blower
^^^ Rawknee posting pictures of his wood is definitely grounds for another time out!
Derrick
Old 07-06-2018, 03:17 PM
Check your "in box" () for the real wood, Deez!!!
Old 07-06-2018, 03:52 PM
The knockers on the wood are a nice touch.
Old 07-06-2018, 05:16 PM
Ha ha - you said "knockers and wood" - nice!
Old 07-06-2018, 05:57 PM
I use ESCO jack stands.
91 535i
73 TR6
Old 07-06-2018, 07:06 PM
If you're thinking of the concrete masonry block aka breeze block they are a definite no!
Old 07-11-2018, 07:22 AM
yes both, with tension taken up but not lifting off the jack stands. It would take a pretty good push to take it off the front stands, the only reason the front one moved was because it slipped off at the rear
I'm still feeling sick about the whole thing.
Old 07-11-2018, 07:23 AM
puddy's Avatar
Hey Rawknees, I must say, now that i've seen your wood, i'm quite impressed.
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 07-11-2018, 08:15 AM
And that's just in its flaccid state - wait'll you see it really jacked up!!!
Old 07-11-2018, 08:23 AM
David's Avatar
Scary stuff. I use one more jack stand than needed just to be safe. So 3 if I’m using 2 and 5 if I’m using 4.
For supporting large turbine parts we use oak timbers. We do not use pine since it’s more prone to split but the wooden blocks above look pretty seasoned.
2014 Cayman S
2011 Cayenne Turbo
Old 07-15-2018, 10:02 AM
mussberger's Avatar
Yeah, mines on them right now. The late USA cars have nice jack points for them to rest on.
1981 911SC Black metallic, no sunroof. Sold(damnit)2005 987Guards Red, Stuttgart build. Sold1978 911SC Bahama Blue, M491 look E class PCA race car.Sold with help from Pelican. Thanks! 2005 997 Black. Sold1988 930 Grand Prix White. Keeper. 2008 957 Basalt Black, Pneumatic suspension and PDCC.
Old 07-16-2018, 08:56 AM
