puddy's Avatar
Thansk Quattro, now I understand better.
Spuggy, I like the idea of boost control tied to RPM, but i'm not sure my SDS will do that. My 915 has all the those goodies to give its best chance for survival. My 2nd and 3rd gear synchros are starting to protest. So I think a refresh is in my future.
Cheers, Chris
1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & outlaw pipe. 915/68 trans, kevlar clutch and lightweight pressure plate.
Old 07-12-2018, 03:11 AM
Originally Posted by puddy View Post
OK maybe I misunderstood the above, I thought I can electronically limit my boost. That the .9 spring would be the upper limit, but I can tune the EBC down to .5 or .6 BAR. No my tranny wont handle the extra EFI power at .9 bar, but if my EBC is turned down it should be ok, i hope!
No the physical spring is the LOWER limit of your max boost. Hope that makes sense. You can't blow off LESS than the spring. The EBC controls the UPPER limit of boost by interrupting the pressure sensing of the physical valve/wastegate.
So, if you have a .9 spring in, whatever the EBC opens at .1, .5, .7, 1.5 whatever, the wastegate will not open below .9.
If you put in a .4 bar spring for example, you can use the EBC to let your wastegate open at anywhere above .4 bar
Old 07-12-2018, 05:52 AM
puddy's Avatar
OK, thanks for clarifying! Really appreciate it!
Cheers, Chris
Old 07-17-2018, 05:24 AM
