Where to buy? Intercooler to WUR hose?
I canít seem to find the part number and mine is cracked
Brighton Rennsport - http://www.instagram.com/BrightonRennsport
http://www.instagram.com/LuftkraftGruppe
1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain
2006 911 4S + 2009 Cayenne GTS + 1962 Austin Healey HiPo 289 Nasty Boy
Old 07-05-2018, 12:12 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
I've never seen a hose going from the intercooler (stock or aftermarket) to the WUR. Can you post a pic of yours? Must be a custom setup.
Old 07-05-2018, 03:11 PM
This hose from the intercooler to what I thought is the WUR?
Old 07-05-2018, 05:30 PM
mark houghton's Avatar
AAV, not WUR. Local auto store, get a piece of radiator hose the same diameter.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 07-05-2018, 05:58 PM
Thanks and sorry for the stupid question, I always thought that was the WUR, where is it?
Old 07-05-2018, 09:51 PM
In your picture, the WUR is directly behind the AAV (auxiliary air valve) - has the electrical connection on top (black cap and gray wire covering), two fuel fittings and hoses, a small vacuum hose that connects to the throttle body, and a vent spout on top.
Also Mark is correct about the hose - typical heater core hose fits perfectly and the hose is very tough (bends without kinking and no problem handling the positive air pressure).
Old 07-05-2018, 10:08 PM
