pressure test engine
I was out driving today, and noticed a vacuum leak... no pressure on the tell tale gauge, so I hooked up the compressor and pressurized the engine, and found leaks at the turbo flange/gasket, slip joint, and throttle body. I think most of the loss of pressure must be from the turbo gasket. Hard to believe that these 3 leaks would leak all of the positive pressure... Another thing that I didn't realize was that I had to test through exhaust end, and intake end. Must be the turbo that wouldn't let the pressure through. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 07-07-2018, 12:51 PM
and the slip joint... any one put a clamp on this? or will it seal up when the exhaust get hot...
Old 07-07-2018, 12:55 PM
Alan L's Avatar
A small amount of leakage in the exhaust is not a problem - the exhaust side operates under very small pressure (not 1 bar). The small leakage at slip joints is a small %age of exhaust gas that is not driving the turbo.
You can do it all thru the intake side. Remember, you may have some valves on overlap somewhere, unless you bring the engine rotation to just before a TDC mark (about 15 deg). At TDC you are 1-2mm open on inlet (and exhaust)somewhere.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-07-2018, 07:42 PM
Those slip joints should seal up with heat. Not sure what headers you have. (Rarlyl8 ?) One of the things I like about the B&B headers is the double slip joint. Smart use of the fuel filter
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 07-07-2018, 09:40 PM
T77911S's Avatar
i had leaks around my TB, mainly the shaft.
no boost pressure?
did it drive like it had no boost pressure?
check the Orings on the IC.
check WG
turbo seized
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 07-09-2018, 09:52 AM
TurboKraft's Avatar
That throttle body o-ring looks like it's pushed out. Shouldn't be visible.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 07-09-2018, 10:05 AM
Looks like a O ring, but its a silicon 135* bend on the throttle body to intercooler, with a T bolt clamp holding it on...
Old 07-09-2018, 11:42 AM
TurboKraft's Avatar
Copy that, thanks for the explanation.
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
Old 07-09-2018, 12:50 PM
