-   -   throw out bearing 'mounting' when re-pairing engine/trans? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1001768-throw-out-bearing-mounting-when-re-pairing-engine-trans.html)
krasuskyp 07-09-2018 06:28 AM
Mornin, germs-
Trying to turn the corner and start putting my motor back in (waaaay overdue), got the motor n trans paired finally - ensuring to catch the TOB ears w/ the release fork.
Question is... the TOB seems to have the ability to 'walk' toward the flywheel.
Is this normal? In that, it's loose there and then is pre-loaded w/ tension by the Omega spring once installed?
Want to be CERTAIN I get this right prior to install.
Regarding the infamous Omega spring... last time I dropped the motor I was able to 'unfurl' it no issue. This time - kerSPRANG... it shot onto the floor in pieces. I'm assuming I didn't break it and it's supposed to do that.
Any tips on re-installing 'that' while we're at it here?
Any insight to both of these quandaries is greatly appreciated - TIA!
timc 07-09-2018 06:40 AM
There's a lot of play on the TB/Fork relationship, just make sure the ears are aligned to catch the fork. It always amazes me that it remains aligned each time i do this. You can look thru one of the holes in the trans to confirm. The Omega spring just need to be pried back in place. I can't remember exactly how I did it, as it's been several years since I've had my motor out. I've got some pictures that may help, send me an email and i'll send to you....timc1018 at hotmail...
krasuskyp 07-09-2018 07:24 AM
THANKS TIM! That makes me feel ALOT BETTER about the TOB! 8-)
YGM!
O-spring... I'd sworn I'd broke it when it let go, but the ends don't have any fresh break look to the metal... hoping thinking I'm OK 8-/
timc 07-09-2018 07:42 AM
pic's sent.
quattrorunner 07-09-2018 10:04 AM
The fork doesn’t always line up correctly it’s awesome that it did for you. But even if it doesn’t it’s not that big of a problem to get it lined up correctly looking through the hole in the transmission. The next biggest problem that is seems you’ve licked is if the disc is not properly centered, if that’s the case then the transmission won’t properly butt up against the engine and that can be exhausting and time wasting. As far as the spring, that’s not a real big deal just make sure you take pictures off the Internet print them out because it can be confusing.
(Your welcome Ronnie)
Ken911 07-09-2018 11:37 AM
Every time I put that spring back in I litterally have to crawl under the car with a copy of the picture in hand to get it right.
krasuskyp 07-09-2018 12:22 PM
lol - thanks Brando / Ken! too funny
yeah, I used Lord Jefferies' SC alignment tool wound w/ electrical tape and it seemed to work a treat - phew
a'ight... may send it north - tonight!
1979-930 07-09-2018 01:31 PM
This post and picture from 2009 :eek: helped me get the Omega Spring back on.
Originally Posted by WERK I (Post 4558162)
I remember! Amazing what a good nights' sleep will do for an ol' man. :)
If you look at Rod's (cl8ton) pic above, and look to the left. You see how the two levers(short and long) mount on the shaft. The long lever does not turn with the shaft but floats. To mount that omega spring, have only the long lever on that shaft. Swing the long lever out towards the bellhousing and then try to mount the spring at its two mounting points. The spring will go on very easy. Once the spring is mounted, push the long lever towards the position in the picture above. The tricky part is keeping the long lever from sliding down that shaft when you've mounted the spring. Two people make it a snap.
You'll be surprised how easy the springs sets in.
http://forums.pelicanparts.com/uploa...1531168274.jpg
mark houghton 07-09-2018 06:42 PM
Fer true....
krasuskyp 07-10-2018 05:25 AM
thanks Derrick! Will give that a shot!
