930 brake replacement
Hi
I have a 76 930 that a previous owner installed the floating rotors and calipers on the front. The rotors are worn down to minimum thickness and I would like to replace. However, replacement costs are excessive and I have read that many people change to the later type fitted from 1980 onwards. Any advice on what exactly needs to be changed? What are your views on this?
Kev
Old 01-12-2019, 12:01 AM
speednme1's Avatar
Originally Posted by kev01 View Post
Hi
Kev
You would need later 930 front hubs...from an 80 on. Then you should be able to use the non floating one piece 930 rotor.
Rey....77 930 "the Mistress"
Old 01-12-2019, 03:54 AM
Take a look at Sebro , they have floating rotors for a more sensible price than porsche.
John
1979 930 - mahle 3.4 (7.5:1),Turbokraft longneck IC, Leask WUR w/rpm solenoid,sc cams, rarlyl8 headers, tial wg, 1 bar boost, GT35R
Old 01-12-2019, 08:36 AM
thanks
Old 01-12-2019, 11:01 AM
stevie 77 930's Avatar
These are a good choice FYI By the time you spend the money on the later hubs $$ and the rotors to match, you would have spent more than a pair of Sebro floating rotors
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 01-12-2019, 12:46 PM
I agree...Sebro seems to be the better option. Any other components that must be changed at the same time... brake flange or ring? Can these be reused?
Old 01-13-2019, 09:09 AM
Yes , you can reuse your existing hardware Have a look at this
'79 930 - Brake refresh in progress
1983 911SC
2018 GTS
2023 Audi A4
Old 01-13-2019, 10:46 AM
