-   -   Early Turbo Trunk Carpet Question (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1015172-early-turbo-trunk-carpet-question.html)
rdwinelover 12-08-2018 08:56 PM
I own an early Turbo from 1977. The original trunk carpet has a burn hole in the carpet from the battery and I want to replace the carpet.
My car is very original and my question is: should I hunt and look to replace the carpet with a used carpet from another car or is there a replacement available in the market that looks just about identical to OEM?
I hate to buy new only to get the carpet and it be miles from original in look and feel.
Thanks in advance.
Jamie
WPOZZZ 12-09-2018 03:17 PM
I have the same burn mark, Jamie. I too, am unsure of what to do. Pelican has a Perlon kit for the trunk, but I can't tell how it is just from the pictures.
rdwinelover 12-09-2018 03:34 PM
Hopefully someone shares their experience Bryan. Thanks for the bump.
rlane930 12-09-2018 06:58 PM
I cut out an oval section from the original bad area (battery acid) and glued in good section from a vintage trunk carpet. It matched perfectly and you can't tell where the glued piece resides. Make sure you cut out the replacement section a little larger than the cutout hole so it will fit tight. The replacements trunk carpets that are available today don't have the same look as the originals.
rdwinelover 12-09-2018 07:04 PM
Thanks Rich. Much appreciated
stevie 77 930 12-10-2018 12:28 PM
i did the same except I brought it to my local dry cleansers/ seamstress and she stitched the repair with almost no visible sign
http://forums.pelicanparts.com/uploa...1544473669.jpg
rdwinelover 12-10-2018 12:29 PM
Thank you guys for the scoop! Its helpful. I found a piece and will do the same!
Bryan, if you need a piece of the carpet, drop me a note as I should have some extra once done.
