Need help with breezy cabin
Could anyone please advise as to why so much cold air is coming through the gauges when I’m at highway speeds? It funnels in like open window.
It would be nice if this was an easy one, but something tells me it’s going to require...
Well, more.
Thanks everyone, just getting my 930 back after a year long ordeal, and this just wasn’t what I was expecting.
Old 12-22-2018, 07:39 PM
Work in Progress
Rich76_911s's Avatar
What work was done to the car over the parr year? Did they have to get up under the dash at all?
I don’t think it’s a huge problem. Certainly not to hard to remove the carpet and pull the little cardboard cover to access the HVAC parts and see if something obvious is wrong. Most likely it’s just a loose pipe or part of the system that is letting air fill up the front trunk and the faster you go the more pressure is pushing air past your gauges.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 12-22-2018, 08:51 PM
You can feel the air coming around the gauges?
Derrick
Old 12-23-2018, 07:35 AM
Ok this may sound stupid, but is the front bonnet latched down all the way? When I pained my last 911 I didn't adjust the front latch properly and it popped up, thankfully on the safety latch not all the way, but it got windy all of a sudden.
If anyone did any work under the dash or in the front trunk area could be either a fresh air vent host is off, or rotted out, or that curved cardboard cover thingie at the rear of the trunk is missing.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 12-23-2018, 10:02 AM
onboost's Avatar
Probably not coming in around the gauges.. your gauges have rubber seals that hold them into the dash and no air passes between them.
Check the bulkhead above the floor, and behind the passenger side footboard. Both these areas have often been modified for better a/c efforts, and then later abandoned with the holes left open. Also, in the smugglers box, under the A/C unit, there.. is a large opening (like a waste line access in a home) that may not be capped off but should be cause it can be one helluva source for air entry into the cabin... guess how I know?
RGruppe #180
Old 12-24-2018, 07:15 AM
Uncertifiable!!!
Uwon's Avatar
As pointed out above, the hood rubber is a primary culprit. Also, the seal around the gas tank, which is more difficult to rectify.
In my RST build, i was always conscious that the frunk should be well sealed to avoid a drafty cabin. In spite of my significant efforts, I ended up with cold knees from a downward draft. I found that I had to go back and “chink” the space between the dash and steel face with foam rubber strips used on windows and doors. Admittedly, I have not yet overcome the remaining draft around the centre A/C vent.
Cheers,
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 12-25-2018, 07:53 PM
