-   -   Where to connect? (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1015796-where-connect.html)
Rayho 12-16-2018 11:37 PM
Where to connect?
Can anybody tell me if this connector is just an optional one or what? I found it yesterday when i was doing some work on the BOV. It`s dusty, so I don`t know if it`s in use...?? Can`t find anywher to connect it...
http://forums.pelicanparts.com/uploa...1545035823.jpg
Rayho 12-16-2018 11:46 PM
http://forums.pelicanparts.com/uploa...1545036301.jpg
Rayho 12-17-2018 04:09 AM
Just an idea. Can it be the connector to the rear blower motor. Maybe the 930 don`t have this motor, and the wire just are there and not connected because the 911 and 930 has the same wire harness.
totle 12-17-2018 05:02 AM
Did not see you posted Raymond, so I posted one recently as well :-)
Now you might have double answers :-)
full quack 12-18-2018 08:54 AM
Your missing 2 nuts on your recirculate piston housing as well!
Mark
heliolps2 12-18-2018 11:59 AM
Hello Turbo friend
Looks like the it would goes to your vacuum solenoid that is used for the emissions diverter coming from you air pump.
stevie 77 930 12-18-2018 02:08 PM
http://forums.pelicanparts.com/uploa...1545174494.jpg
flightlead404 12-18-2018 05:30 PM
That one's not for the airpump, its to block vacuum retard to the distributor I think. Its inline between the nipple on the dizzy can closest to the dizzy body and port I on the rear LHS of the throttle body. Controlled by the thermo switch in the chain housing LHS if I remember correctly.
The vacuum solenoid-valve (37 in the hose plan diagram for an '86 930) is plumbed thusly:
-Nipple underneath the electrical connector to the throttle body
-Nipple opposite the electrical connector vents to atmosphere
-Nipple on top at 90 degrees to the distributor
Rayho 12-19-2018 06:23 AM
Yes. Its that one. Its removed on my car so i belive its no where to connect it:)
Mark
I know. In the middle of a job with it;)
