In Dash Boost Gauge
'80 SC 3.0 to 3.2SS turbo conversion in progress (0.8 bar)
Ordered a boost gauge from North Hollywood Speedometer to be custom built with the 2bar range being -0.5 to 1.5 The gauge is listed as 2-1/16" dia so my plan was to mount it on the console along with a similar diameter AFR gauge.
Picked up today and to my delight, the gauge size is identical to my clock !
Not cheap, but it's a work of art (even with a VDO faceplate).
I was having my clock repaired at the same time and maybe that inspired him ?
5star review for NoHo Speedo
Always take the high road, it's far less crowded - Charlie Munger
Old 02-08-2019, 12:25 PM
Capt Bob
Capt Bob's Avatar
I have a similar gauge in my 930...wish my gauge showed vacuum.
Old 02-09-2019, 05:49 AM
Old 02-10-2019, 10:25 AM
Good luck--the one I have from NHS rattles like mad, and isn't very accurate. Not surprised they stopped putting their initials on them...
I'll be sending mine to Palo Alto; they have a better reputation.
Old 02-10-2019, 01:51 PM
scottrx7tt's Avatar
What brand is your boost gauge?
Originally Posted by moty View Post
Old 02-10-2019, 02:59 PM
Shame to hear about the quality issues. As I’ve searched and searched for an 80mm boost gauge, those are the only ones that look alright. Any way to bury a basic smaller VDO boost gauge with similar font inside the clock bezel?
Old 02-10-2019, 06:47 PM
scottrx7tt's Avatar
There are several 80mm boost gauges that appear on eBay. I ran a greddy unit for awhile that fit and looked great. There is also this one. You can take the light and the controller off of it
https://www.ebay.com/itm/80mm-Black-Face-Boost-Gauge-with-warning-and-peak-and-outside-shift-light-BAR/231981099553?hash=item360326aa21:g:ITYAAOSwOVpXYnM f
Old 02-10-2019, 07:07 PM
Alan L's Avatar
Mine is a Greddy - unfortunately can't take a pic right now. Works fine - goes from -0.75 to 1.5.
Fits where the clock was. More interested in boost than the time of day.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-10-2019, 07:54 PM
Needs more flair.
Old 02-11-2019, 08:44 AM
VDO "Cockpit" series match the rest of the instruments pretty well, optionally available with vacuum, and various maximum ranges - 15, 25 PSI are pretty common. Either these, or the VDO "Vision" series (slightly different lettering) usually run $60-80 brand new.
Think they're 52mm (2 1/16") diameter. You need something to bridge the gap. Like an old clock shell, or a round plate.
Some examples:
'77 S with '78 930 power and a few other things.
Old 02-11-2019, 05:37 PM
