Goofy looking. The very low price might indicate it’s not all that good.
Old 01-31-2019, 08:22 AM
gumba's Avatar
Not sure the guy knows what he has since he mentioned it's made out of stainless steel.
Harold
'79 930/DP935
'68 VW 3.3 Turbo Crewcab
Old 01-31-2019, 08:39 AM
Turbonut
Raceboy's Avatar
It has good core, why is something that is unfamiliar to someone, goofy and therefore not good? Just because person looking at it is no familiar with it or..?
'83 924 2.5 16v Turbo, 530hp @ 1.5bar
'67 911 widebody hot-rod /2.4S
http://www.facebook.com/vemsporsche
Old 01-31-2019, 09:47 AM
My apologies if I offended you. I didn’t realize some are so sensitive.
Old 01-31-2019, 09:55 AM
I have seen one ore two of these on e-bay a few years ago. I did some research and was told they are not designed specifically for Porsche 930 motors but a V-configuration motor. Not sure if this is accurate but made sense to me as the inlet and outlet would require additional plumbing.
Rahl
Old 01-31-2019, 12:42 PM
scottrx7tt's Avatar
I've seen worse, but I am sure it would work ok, but not ideal for a 930, given the inlet/outlet locations. Would be better off with an ebay universal intercooler.
1979 911SC widebody conversion. 3.1 engine, 3.2 liter heads, carrera intake, Microsquirt V3 ECU, K27 7200 High flow turbo, Tial F41 wastegate, Ford EDIS. .7 bar. 402hp 360tq
Old 01-31-2019, 01:07 PM
Brando
quattrorunner's Avatar
Tight curve back to the tb.. Could be fixed with an outlet change I guess.
Turbo powa!
1977 911s. it's cool
Old 01-31-2019, 04:46 PM
Chain fence eating turbo
Stainless steel construction?
That’s funny!
You can find those IC’s all over the Internet for cheap.
Old 01-31-2019, 05:49 PM
Turbonut
Raceboy's Avatar
Rahl
Please explain what type of cooled air does v-engine and what type 930 engine requires?
This thread is a good indication that people tend to think that 930 is something so special that even intercooler has to cost thousands in order to be even remotely suitable for the car.. Gee..
That intercooler in the ad is just a standard FMIC, it is a quality one, good core, high flow vertical core, just not made for 930, that's all.
Old 01-31-2019, 08:43 PM
This would be a "V" configuration motor...V-4, V6, V8...not the juice
But I guess you could plumb anything into any engine if the intercooler is cheap enough. This is a good opportunity for someone to dig up some wild plumbing solutions "Rube Goldberg style". Maybe this Intercooler will show up.
Old 02-01-2019, 10:00 AM
gumba's Avatar
So for anyone who is going to swap out the 930 motor for a V8.
Harold
'79 930/DP935
Old 02-01-2019, 10:01 AM
1) because it is cheap, dosnt mean it is bad.
2) this is a standard non-porsche IC (actually two cores + casted end pieces welded together) straight from one of the biggest suppliers of IC in china. It is a very good IC for routing in and out in same side, very common style IC. It has a nice core - just as good as any other for that size. I have an excact same version in slightly used condition on the shelf that came of a 930 3.0 turbo raced engine with the same 930 adapted brackets still on. Happy to sell that IC for less, with shipment out of Europe if anyone interested.
I agree with Raceboy, the porsche community is different from rest of the tuning market.
Old 02-06-2019, 01:23 PM
scottrx7tt's Avatar
This one would be a much better choice. All you have to is change the orientation of the “in” pipe. Gonna be buying this one in a few weeks
https://www.ebay.com/itm/CXRacing-Bolt-on-Upgrade-Intercooler-For-2007-Mitsubishi-Lancer-Evolution-EVO-X/160605064466?epid=658092302&hash=item2564cecd12:g:56UAAOSwEK9XAg2M
Old 02-06-2019, 02:02 PM
'76 911S 3.0's Avatar
The Evo X intercooler style works well with an inlet change:
Here is how it was originally configured:
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, ARP Rod Bolts, Big Port SC Heads, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-06-2019, 05:15 PM
scottrx7tt's Avatar
Wow, perfect fit! Looks great.
Old 02-06-2019, 06:27 PM
baloo's Avatar
Thanks for the info,Scott.
Do you have anyidea of the dimensions of this IC?
Are you putting this on a 930, or a "911-turbo"?
I am doing a 911-turbo, and this price is ridic-good.
Old 02-07-2019, 09:49 AM
scottrx7tt's Avatar
Mine is a turbo conversion. I have a Carrera intake. The dimensions are posted on the eBay ad. I ordered it last night. I have another intercooler I bought from another pelican that I have used the last few years but was never happy with the fitment
Old 02-07-2019, 10:06 AM
Technically I changed the EVO X "outlet" orientation, the "inlet" is actually the outlet and feeds into the throttle body with a 90° elbow, a short 10" straight, then another 90° elbow. I am not using the CX Racing version, but rather a prototype version AEM Intakes made years ago with a Garrett core, but I will say it works fantastic. Intake temps are ambient in any condition as long as the vehicle is moving. Sitting still subjects the core to radiant heat but that applies to all applications.
-Jayson
IG: Signature_911
Old 02-07-2019, 02:37 PM
scottrx7tt's Avatar
I searched pretty extensively on eBay for an off the shelf solution for the 911/930. Was pretty set on the 93-95 rx7 v mount intercooler but would have to flip one of the end tanks and reorient the intercooler outlet. Too much work, especially after seeing the evo X. Here is a link to the rx7 v mount.
https://www.ebay.com/itm/CXRacing-Universal-3-35-V-Mount-Intercooler-For-FC-RX7/161353881312?epid=655245302&hash=item259170d6e0:g:Uf0AAOSw7I5TskSf
Old 02-07-2019, 03:11 PM
