Per Alan:
[COLOR="Blue"]"And just to complicate it more, you could have a couple of crappy injectors that are not shutting off when Off. Dribbling fuel into cylinders, which = rough starts".[/COLOR Once you've confirmed that both pumps are indeed running, then certainly a good possibility that you've got some injectors slowly leaking down in to the cylinders as the car sits, basically flooding the engine. If this happens again, try a standard flood start: Hold the gas pedal all the way to the floor and crank. That will let more air in to the engine to overcome the richness and help starting. You were kind of doing that with pumping the pedal. |
Peddling/pumping the accelerator is an old trick for carbureted cars; carbs have an accelerator pump that squirts a small amount of raw gas into the intake when pumping the pedal. Not so with CIS, so I can't see where this action has anything to do with making your car start. Don't you get a dump of fuel the instant you open the plate in the air flow sensor? I have been known to peddle the gas for a dump of fuel to start my car after sitting a couple of weeks without being started, always works for me.:confused: |
I've never needed to "peddle" regardless of the temp. |
For benefit of the questioner, the cold start valve actuates when the starter is cranking and will spray gas for just a couple seconds until it "times out", or it won't spray at all when the engine is warm (thus, the thermal time switch). Once the engine starts and injectors start spraying, the rich mixture is maintained and managed by the WUR in it's cold warm up rich mode whereby it adjusts the fuel control pressure based on temperature. Aint CIS fun???Sorry we got a little off-topic.... |
Just to tidy the CSV bit up - there is no timing in that circuit. It is hooked in to the starter circuit. While you crank the starter it works/does not work - depending on engine temp. The TTS either makes or breaks the circuit.
Regards Alan |
Anyway not to detract from the POs problem I will try without the pedal next time. SBK 930, I also recommend CIS gauges. Learning how to test pressures, analyze afr, make adjustments to wur and fuel mix are all part of the fun of owning one of these cars. Good Luck |
As for the TTS, is there an internal heating element that in effect acts as the "time" portion of the TTS name, whereby it will reach 35C and switch off the CSV after a period of time cranking the cold engine, thus preventing flooding for a hard to start vehicle? |
Its at O 43 on my wiring diagram ('86). |
OK - my bad - internal heater. Makes sense - limits the amount of fuel dumped in engine if not firing.
Regards Alan |
| All times are GMT -8. The time now is 01:53 AM. |
