SBK930's Avatar
Oil leak link
So my turbo is again leaking from the compressor side.
I found the breather from the case to the oil tank also leaking.
Now after researching for causes, I found this pipe can get quiet a lot of oil slung into it. If this breather is flowing oil to the tank it can be said that there is no blockage which I read blockage could cause crank case pressure to build. In turn this pressure can force oil into the turbo and if filled above the shaft bearing/seals oil will run into the housing.
With a correct functioning check valve this should not be possible.
A scavenge pump that is correctly working and not allowing flow back to the catch tank would not allow the turbo to fill with oil either.
So if this is a correct summary the oil leak has to be from the turbo when it has been running and when parked the oil seeps from the up pipe connection.
Of course if I gave it a boot full of boost to clear the compressor side immediately prior to shut down the oil would be pushed back up through the IC.
Sound plausible ???
Old 02-04-2019, 02:08 PM
T77911S's Avatar
what turbo do you have
who rebuilt it if is was rebuilt.
don't remember your details
if you have oil in the hose form the case to the tank you may have too much oil in it. I never fill mine up. I try not to go past half way. excessive blow by past the rings could also cause too much oil in that hose.
are you getting smoke all the time or just at startup.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 02-05-2019, 05:23 AM
SBK930's Avatar
Hi T77911S,
No smoke at startup unless I have had the rear jacked up. Smokes when accelerating on boost.
Running a 7006 rebuilt 4 times and oil is never past half way.
I am so over it
Decided to do an experiment to prove the rebuild again is fracked ....... so purchased a new K27.
ps if this does not fix it I will have a slightly burnt out 1978 930 for sale .....
going cheap.
Steve.
Old 02-05-2019, 10:59 AM
T77911S's Avatar
i understand the frustration
how bad is the smoke.
could it just be too rich
RACE CAR:: sold
Old 02-06-2019, 07:20 AM
SBK930's Avatar
Runs fine on cruise.
Gives a light cloud when boost kicks in.
Park it, and end up with oil seeping from the connection to the up pipe.
Steve.
Old 02-06-2019, 09:51 AM
SBK930's Avatar
New turbo should arrive today.
My thought is that when the 7006 detonated the core assembly has realy been damaged beyond repair.
It had to be machined/honed for oversize bearings and now there is a discrepancy that when first put together runs fine on the VSR yet starts to fail after driven.
Hoping this weekend I will have swapped the turbos over and have some joy.
And no more
Steve.
Old 02-06-2019, 10:14 AM
SBK930's Avatar
Turbo removed and Awaiting new 7200 today.
I found no oil in the turbine exhaust side, the core assembly was not full, and yet again the up pipes to the intercooler and air cleaner are oily along with the compressor side that had a small puddle of oil in it.
Old 02-07-2019, 02:52 PM
SBK930's Avatar
New turbo arrived.
Now to clock it and install.
Old 02-07-2019, 05:31 PM
SBK930's Avatar
DONE !
Up at 3am to watch King of the hammers
Started turbo install a little after 10 and with a little shoe horning the 7200 is in.
Old 02-08-2019, 05:55 PM
Great news Steve! Looking forward to your driving impressions with the new K27!
Rahl
Old 02-10-2019, 11:42 AM
SBK930's Avatar
Rahl
Hi Rahl,
So far I have only tentatively brought it up to boost.
However so far I have not been able to say that there is a lot of difference.
The 7006 turbine side has a larger exhaust opening by around 5mm compared to the 7200, with the compressor sides being very close to the same. An interesting difference is the smaller internal diameter of the up pipe from the compressor in the 7200.
Next task I am really looking forward to is the replacement of the rear CV boots.
NOT !!!
Old 02-12-2019, 08:50 PM
